[mapguide-users] FDO PostgreSQL/PostGIS provider on 64bit
ar_gaeta riccardog79 at gmail.com
Fri May 17 04:15:57 PDT 2013
Hi all. I have the same problem on a Windows Server 2008 64bit.
I'm using MGOS 2.4 32bit, and when I try to load a postgresql feature source
by Maestro I get an error.
I check the provider.xml and it is okay.
I check the PostgreSQLProvider.dll with "dependencywalker/defense.exe" and
all it's okay.
I had first installed a postgresql version 9.2 with postgis 2.0, 64bit, and
add the relative /bin path to the windows path, but I get an error.
Then I've tried the provider against the libpq.dll provided by a postgresql
8.4 with postgis1.5, 32bit, but nothing, I get the same error and the
provider is not working.
It's not only a problem of Maestro I mean I check the provider on
WebTierTests-GetCapabilities and I get the same error.
Where could  be the problem??
Thanks to all, please give me some advice
Riccardo
Here my error:
Errore del server remoto: (559) MgFdoException.:
An exception occurred in FDO component.
Unable to load the FDO Provider library
System.Exception: Errore del server remoto: (559) MgFdoException.:
Unable to load the FDO Provider library '.\PostgreSQLProvider.dll':
Impossibile trovare il modulo specificato.
  (Cause: , Root Cause: Unable to load the FDO Provider library
'.\PostgreSQLProvider.dll': Impossibile trovare il modulo specificato.
 ---> System.Net.WebException: Errore del server remoto: (559)
MgFdoException.
   in System.Net.HttpWebRequest.GetResponse()
   in OSGeo.MapGuide.MaestroAPI.HttpServerConnection.OpenRead(String req) in
c:\Program Files (x86)\Jenkins\jobs\Maestro
4.0.x\workspace\OSGeo.MapGuide.MaestroAPI.Http\HttpServerConnection.cs:riga
1221
   --- Fine dell'analisi dello stack dell'eccezione interna ---
1237
   in
OSGeo.MapGuide.MaestroAPI.HttpServerConnection.GetProviderCapabilities(String
provider) in c:\Program Files (x86)\Jenkins\jobs\Maestro
1662
   in Maestro.Base.Editor.FsEditorOptionPanel.Bind(IEditorService service)
4.0.x\workspace\Maestro.Base\Editor\FsEditorOptionPanel.cs:riga 60
   in Maestro.Base.Editor.FeatureSourceEditor.Bind(IEditorService service)
4.0.x\workspace\Maestro.Base\Editor\FeatureSourceEditor.cs:riga 63
   in Maestro.Base.Editor.EditorContentBase.set_EditorService(IEditorService
value) in c:\Program Files (x86)\Jenkins\jobs\Maestro
4.0.x\workspace\Maestro.Base\Editor\EditorContentBase.cs:riga 81
   in Maestro.Base.Services.OpenResourceManager.Open(IResource res,
IServerConnection conn, Boolean useXmlEditor, ISiteExplorer siteExp) in
4.0.x\workspace\Maestro.Base\Services\OpenResourceManager.cs:riga 164
   in Maestro.Base.Services.OpenResourceManager.Open(String resourceId,
4.0.x\workspace\Maestro.Base\Services\OpenResourceManager.cs:riga 220
View this message in context: http://osgeo-org.1560.x6.nabble.com/FDO-PostgreSQL-PostGIS-provider-on-64bit-tp4183551p5053958.html
