[mapguide-users] How to use WMS with the Layer Map Definitions
Andrey Maraev asmaraev at gmail.com
Tue May 21 07:09:29 PDT 2013
If you mean "Can I add coordinate system overrides though the validate
buttons" then yes I can.
May you explain If I have the data files with EPSG:32648 SRS may I
configure it with WMS provider? Because default SRS in WMS provider is
EPSG:4326, right? That is why I see just empty white screen in qGIS.
2013/5/21 Jackie Ng <jumpinjackie at gmail.com>
> MapGuide must be having some issue with either the coordinate system
> dictionaries or the coordinate system in question.
> Are you able to pick this coordinate system from a list when you use
> Maestro?
> - Jackie
> http://osgeo-org.1560.x6.nabble.com/How-to-use-WMS-with-the-Layer-Map-Definitions-tp5054429p5054600.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
lernen,lernen und lernen
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20130521/00f6945a/attachment.html>
