[mapguide-users] Maestro4 RenderRuntimeMap different output from LocalNative and Http connection.
Hans Milling hm at geograf.dk
Thu May 23 03:52:38 PDT 2013
Hi Jackie
I've just updated the source as you told and recompiled the API. It makes no
difference how the render behaves. There is another problem also.
I use this to generate tiles that I stitch together to form very larg print
(like A0).
To solve the original problem I compensate the different scales this way:
The tiles generated does not have features that extent from the neighbour
tiles, like text lables, they get cropped. Look at the two PDF files
attached printed with the excact same parameters, center, scale etc. They
also show how different the localnative and http connection behaves:
http.pdf <http://osgeo-org.1560.x6.nabble.com/file/n5055201/http.pdf>
LocalNative.pdf
<http://osgeo-org.1560.x6.nabble.com/file/n5055201/LocalNative.pdf>
Hans...
View this message in context: http://osgeo-org.1560.x6.nabble.com/Maestro4-RenderRuntimeMap-different-output-from-LocalNative-and-Http-connection-tp5055145p5055201.html
