[mapguide-users] Problems with Navigator and Fusion Map Controls
Bernhard Maehler bernhard.maehler at gmx.de
Mon May 27 09:58:13 PDT 2013
I noticed an issue with Fusion navigator and map controls (e.g. QuickPlot or
Measure).
System: MapGuide 2.5, bundled version with Apache and PHP
Examples:
1) QuickPlot
- start QuickPlot
- activate checkbox 'Advanced Options'
- move mouse cursor over navigator
-> the capture box (preview) can't be moved anymore
2) Measure
- start Measure
-> the command is broken and doesn't work anymore
Meanwhile I found out that the reason for this issue are these lines of code
in Navigator.js (line 155 to 158):
        this.domObj.addEvents({
          mouseenter: OpenLayers.Function.bind(this.mouseEnter,this),
          mouseleave: OpenLayers.Function.bind(this.mouseLeave,this)
After I've commented out these lines everything works perfect.
I am not a programmer, but what is the reason for disabling active map
controls when the mouse cursor is over the navigator?
Thanks,
Bernhard
View this message in context: http://osgeo-org.1560.x6.nabble.com/Problems-with-Navigator-and-Fusion-Map-Controls-tp5056203.html
