[mapguide-users] Select specific layer and feature by passing value to flexible layout (AIMS2014)
Jackie Ng
jumpinjackie at gmail.com
Mon May 27 21:41:49 PDT 2013
The query geometry is not meant to be a point. It's meant to be a box (ie a 5
coordinate polygon).
When you click to select a feature, the viewer does not pass a point. It
passes a box derived from the clicked point inflated by a small factor.
Your code should be doing the same thing.
- Jackie
View this message in context: http://osgeo-org.1560.x6.nabble.com/Select-specific-layer-and-feature-by-passing-value-to-flexible-layout-AIMS2014-tp5055669p5056291.html
