[mapguide-users] Change log to show PC Name if available
Jamo
adam.jamison at portbris.com.au
Tue May 28 22:57:25 PDT 2013
Sorry Zac I'm not following what you mean AWStats would interpret mapguides
.log files ??
I was hoping the log files that mapguide produces could be modified I'm able
to open the logs stored in mapguide\server\logs\access*.log
The log only lists the IP address not the PC Name, supposedly our IP
addresess change from time to time and the PC Name is a little more static.
I've just interpreted the log for the last 6 months and informed them we
have had roughly 40 solid individual users of our internal GIS and they
would use the GIS roughly 15 days a month each, in reality the numbers might
be a little less, just want to make sure I'm giving the right
information....
actually reading the log file is a once off task.
Cheers
MapGuide Maestro 5.0b
MapGuide Opensource 2.2.0.5703
Fusion, PHP, Apache
Windows Server 2008 64bit
View this message in context: http://osgeo-org.1560.x6.nabble.com/Change-log-to-show-PC-Name-if-available-tp5056604p5056610.html
