[mapguide-users] Fusion Event Listeners Called Twice
ChrisGo
cgountanis at mpowerinnovations.com
Wed Nov 6 07:31:30 PST 2013
Zac,
I only have one map in set application XML file. I do load the map into the
session like Maestro does for previews but yes, only one map.
e.g.
string resourceid = mg.SaveSessionResource(mapguidesessionid,
"MyMap.ApplicationDefinition", contentxml);
<MapSet>
<MapGroup id="MainMap">
<Map>
<Type>MapGuide</Type>
<SingleTile>True</SingleTile>
<Extension>
<ResourceId>Lib://....etcSINGLEMapDef</ResourceId>
<SelectionAsOverlay>true</SelectionAsOverlay>
</Extension>
</Map>
</MapGroup>
</MapSet>
As far as version I am using MapGuide 2.6 with what I think to be the latest
Fusion.
Jackie,
I switch to the non-compressed JS in the slate template which is the default
we use right now for concepts. I understand line 1 for everything is not
easy to debug. This at least gives line numbers now, my bad.
Single selection mouse click on selectable layer.
First Hit
http://i.imgur.com/8zYKeQf.png
Second Hit
http://i.imgur.com/lVUpYjg.png
View this message in context: http://osgeo-org.1560.x6.nabble.com/Fusion-Event-Listeners-Called-Twice-tp5087525p5087677.html
