[mapguide-users] Optimizing Mapguide Server -Cache Size
Zac Spitzer
zac.spitzer at gmail.com
Thu Nov 28 03:45:11 PST 2013
might be worth bumping these default numbers up?
the original numbers were set for resource limited computers almost ten
years ago
On Thu, Nov 28, 2013 at 8:54 PM, Jackie Ng <jumpinjackie at gmail.com> wrote:
> To give you better insight, this is what MapGuide caches on the
> server-side.
> - Feature Source documents
> - Spatial Contexts
> - Feature Schemas
> - Class Definitions
> - Identity Properties
> Of your 320 layers, you have to ask yourself:
> - How many feature sources all these layers point to in total?
> - Of this set of Feature Sources:
> - Are they flat-files? (generally one class per feature source)
> - Are they relational databases (one class for each table per feature
> source)
> - Are you serving this data in various coordinate systems (one spatial
> context per CS)
> Based on this information you can roughly tally up the number of
> potentially
> cacheable items and set the cache size appropriately.
> Hope this helps.
> - Jackie
> http://osgeo-org.1560.x6.nabble.com/Optimizing-Mapguide-Server-Cache-Size-tp5091621p5091633.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer
+61 405 847 168
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20131128/cd08c373/attachment.html>
