[mapguide-users] Fusion OverviewMap commercial layers no showing
scoobylx brandon.mason at maritimearchaeology.co.uk
Thu Oct 3 08:35:44 PDT 2013
Greetings,
First post - please go easy. I've been using mapguide since 2.0, but only
recently switched to fusion since 2.5. Enjoying mapguide with my postGIS
setup a lot, but I have some issues that I am just stumped with. I'll limit
this post to one issue.
I cannot figure out how to get the OverviewMap widget to show commercial
basemapping: Google, Bing or even MapNik. I have my vector layers showing
fine on the mainmap and in the overview.
I am using spherical Mercator (WGS84.PsuedoMercator) on the map definition.
I have manually entered the map extents
I have checked that the correct maps apis are being called in the xml
definition
I have added google friendly zoom levels
Do I need to define map projection or other parameters in the widget xml? Is
there any reference for XML parameters that can be added to the widget to
define map projection, etc?
I am only using the fusion templates for now. Does the basic template
OverviewMap widget xml need more parameters to load a commercial layer? I
have tried adding those layers identified in the preceding MapSet, but going
nowhere fast.
My setup: Windows Server 2008 r2 x64, mapguide OS 2.5.1 x64, IIS 7.5,
feature sources: tested with SDFs and Postgis 1.5.5.
Many thanks for your time, and patience!
Brandon
View this message in context: http://osgeo-org.1560.x6.nabble.com/Fusion-OverviewMap-commercial-layers-no-showing-tp5081661.html
