You have to fix the paths in webconfig.ini as well so the mapagent knows where to pull the template/widget info xml files from. - Jackie -- View this message in context: http://osgeo-org.1560.x6.nabble.com/Fusion-2-6-Preview-available-tp5082362p5082500.html Sent from the MapGuide Users mailing list archive at Nabble.com.
