[mapguide-users] Fusion cannot establish connection to the Mapguide Server
Riccardo Pucci
riccardo.pucci at dbcaditaly.com
Mon Oct 21 06:40:19 PDT 2013
Hi
Check inside serverconfig.ini (on the server): the MachineIp and
IpAddress parameter should have the exact same value as IpAddress in
webconfig.ini.
For example if on serverconfig.ini you have 127.0.0.1 you should change
to 192.168.177.128.
Riccardo
Il 15/10/2013 16:31, Liglio ha scritto:
> Hi,
> I have a server installed with Windows server 2012 and mapguide server 2.5.
> I am developing a application using Fusion and .NET. When the application is
> installed at the server everything works fine, but if I try to run the
> application from my workstation Fusion recieves a html response "Cannot
> establish connection to the Infrastructure Map Server" as shown below. The
> webconfig.ini is pointing to the right server IP address at
> SiteConnectionProperties (IpAddress=192.168.177.128).
> If someone can help, I appreciate.
> var appDefUrl = Fusion.getQueryParam('ApplicationDefinition');
> if(appDefUrl && (
> appDefUrl.indexOf('Library') == 0 ||
> appDefUrl.indexOf('Session') == 0)){
> var passedSessionId = Fusion.getQueryParam('Session');
> if(passedSessionId == null || passedSessionId == "" ){
> createSessionId(Fusion.getQueryParam("Username"),
> Fusion.getQueryParam("Password"));
> }else{
> Fusion.sessionId = passedSessionId;
> var xhr = new getXmlHttpRequest();
> var mapAgentUrl = getAgentUrl();
> xhr.open("GET", mapAgentUrl +
> "?OPERATION=GETRESOURCECONTENT&VERSION=1.0.0&LOCALE=en&CLIENTAGENT=MapGuide+Developer&RESOURCEID="
> + appDefUrl + "&FORMAT=text%2Fxml&SESSION="+ Fusion.sessionId, false);
> xhr.send(null);
> //******************** The error is here ***********************
> //***** xhr.responseXML is null and xhr.response is shown bellow
> var appDefXML = xhr.responseXML.documentElement;
> if(appDefXML){
> var googleElement =
> appDefXML.getElementsByTagName("GoogleScript")[0];
> var yahooElement = appDefXML.getElementsByTagName("YahooScript")[0];
> var veElement =
> appDefXML.getElementsByTagName("VirtualEarthScript")[0];
> var osmElement =
> appDefXML.getElementsByTagName("OpenStreetMapScript")[0];
> addElement(googleElement);
> addElement(yahooElement);
> addElement(veElement);
> addElement(osmElement);
> xhr.response:
> <html>
> <head>
> <title>MgConnectionFailedException</title>
> <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
> </head>
> <body>
> Problem:\nCannot establish connection to the Infrastructure Map
> Server.\n\nPossible Causes:\n-Your session has been idle for too
> long;\n-Infrastructure Map Server is no longer responding;\n-Internet
> connection problems.\n\nSolution:\nRestart your application / session,
> restart the Infrastructure Map Server service, or contact with the server
> administrator.
> administrator.
> </body>
> </html>
> View this message in context: http://osgeo-org.1560.x6.nabble.com/Fusion-cannot-establish-connection-to-the-Mapguide-Server-tp5083718.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
