[mapguide-users] Remove Map Overview window
Jackie Ng
jumpinjackie at gmail.com
Thu Oct 24 03:59:41 PDT 2013
Aqua is a special case because everything in that template is floating
windows.
For the other templates which are all panel-based, I think you just have to
remove/comment out the actual div element with the same id so Fusion can't
find it to attach the OverviewMap widget onto it. You may also need to
modify any setup code in that template that assumes an OverviewMap panel
will be present.
- Jackie
View this message in context: http://osgeo-org.1560.x6.nabble.com/Remove-Map-Overview-window-tp5059942p5085577.html
