[mapguide-users] Opening a window using an invoke url custom command with the toolbar
Berg, James James.Berg at stantec.com
Tue Sep 3 08:01:06 PDT 2013
Okay, looks like I solved my own problem again. I suppose I'll post the solution.
In mainframe.templ under the function OpenUrlFromForm() I modified the line:
else if(cmd.targetType == 2)
        targetName = "newFrame" + (newWindowIndex ++);
        window.open("", targetName, "toolbar=no,status=no,width=500,height=500,resizable,scrollbars");
to read:
        window.open("", targetName, "toolbar=no,menubar=yes,status=no,width=500,height=500,resizable,scrollbars");
The only new inclusion is the menubar=yes, in the window.open() call. This would apply to every window launched this way, though, I can't say I figured out how to make individual custom commands launch with different window properties.
Sent: Tuesday, September 03, 2013 9:16 AM
To: mapguide-users at lists.osgeo.org
Subject: Opening a window using an invoke url custom command with the toolbar
MGOS 2.4
Maestro 5.0.0
Windows Server 2003 r2
Hello, all
When I create an invoke URL custom command the window it opens doesn't have the toolbar. I want the users to be able to access the print options normally available. Is there a way to open these windows with the toolbar?
Thanks for all the help
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20130903/16ddf04b/attachment.html>
