[mapguide-users] Tooltip Error for layers not on top
Marco Cussino
mcs at gdtest.it
Wed Sep 4 02:11:32 PDT 2013
Do you mean in tooltip content ?
I'm working with different data sources.
I've found some tests and in another installation with MG 2.4.0 this problem is not present.
I found that the only differences between the 2 server are
GD.dll
GEOS.dll
copying DLL from the server where i hadn't the problem to the server with this issue it seems to solve my problem.
I made also a test with a fresh installation of MG 2.4.0 and also on this setup I had the issue and solved it replacing this 2 files from the server where the issue was not present.
Marco
----- Original Message -----
To: mapguide-users at lists.osgeo.org
Sent: mercoledì 4 settembre 2013 3.29.37 (GMT+0100) Europe/Berlin
Subject: Re: [mapguide-users] Tooltip Error for layers not on top
Are you working with non-english content?
- Jackie
View this message in context: http://osgeo-org.1560.x6.nabble.com/Tooltip-Error-for-layers-not-on-top-tp5075848p5075910.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20130904/6a049dbe/attachment.html>
