[mapguide-users] [MapGuide 2.4.0]WMS GETFEATUREINFO issue and 2 questions
Rémy Gourrat rgourrat at ag-carto.fr
Mon Sep 9 01:55:03 PDT 2013
I consume a mapguide wms service with an autocad map or with Gaï 3.4.
I can display maps under Autocad Map.
1 - Question :
But i can't have the result of GETFEATUREINFO
with Autocad Map i have this message:
"LayerNotQueryable:
  The GetFeatureInfo request contains the names of layers that are not queryable. (Found LAYERS=EPFL/2 - Calques/CAD/CAD_COMMUNE)"
With Gaia 3.4 I have this :
[cid:image002.png at 01CEAD4A.84C17860]
[cid:image001.png at 01CEAD47.DF4027D0]I check with Maestro I have the right parameters like this
Is there another parameter somewhere to run GETFEATUREINFO ?
2 - Select QUERY
I searched in ogc but I didn't see a syntax to specify a where clause to the getmap url, really no way ?
3 - in trac.osgeo.org for 2.4.0 release I read : WMS 1.3.0 support
But when i try to connect in 1.3 with Autocad Map 2013, GETCAPABILITIES return no layers in the fdo connect panel.
If I try in 1.1.0 GETCAPABILITIES return the Layers
Autodesk says that Autocad Map 2012 certified by OGC, i suppose that's same for 2013...
Thanks
Rémy
image001.png (42K) <http://osgeo-org.1560.x6.nabble.com/attachment/5076803/0/image001.png>
image002.png (53K) <http://osgeo-org.1560.x6.nabble.com/attachment/5076803/1/image002.png>
AG-Carto - Bayonne
View this message in context: http://osgeo-org.1560.x6.nabble.com/MapGuide-2-4-0-WMS-GETFEATUREINFO-issue-and-2-questions-tp5076803.html
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20130909/dadd7bbc/attachment.html>
