[mapguide-users] BASEMAPSWTICHER
Greg gbneff at cid.utah.gov
Mon Sep 9 10:30:42 PDT 2013
I was eavesdropping on this post because I have had the same question.  I
tried Andy's code in the fusionInitialized function and it does set the menu
item to none but the base map has already loaded.  A mapReload doesn't
change things.  You have to manually select the base map for it to change.
MGOS 2.5.1
Windows 7
View this message in context: http://osgeo-org.1560.x6.nabble.com/BASEMAPSWTICHER-tp5018001p5076929.html
