[mapguide-users] [MapGuide 2.4]Composite symbole in MapUnits
Rémy GOURRAT rgourrat at ag-carto.fr
Wed Sep 18 08:17:17 PDT 2013
Thanks Jackie,
I replace it like this, I can validate it with maestro editor Xml
<?xml version="1.0"?>
<LayerDefinition xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" version="2.4.0" xsi:noNamespaceSchemaLocation="LayerDefinition-2.4.0.xsd">
  <VectorLayerDefinition>
    <ResourceId>Library://ZZ_Test/Data/ORA_PLU.FeatureSource</ResourceId>
    <Watermarks />
    <FeatureName>KingOra:ORA_PLU~V_PLU_PRE_S_05_LBT_MPG~GEOM_LBT</FeatureName>
    <FeatureNameType>FeatureClass</FeatureNameType>
    <Filter>IDPLU_VERSION = 0</Filter>
    <Geometry>GEOM_LBT</Geometry>
    <ToolTip>concat ('ER n° : ', LIBEPSC, '\n', ER_DESTINATION, '\n', ER_ATTRIBUTAIRE)</ToolTip>
    <VectorScaleRange>
      <MaxScale>5000</MaxScale>
      <CompositeTypeStyle>
        <CompositeRule>
          <LegendLabel />
          <CompositeSymbolization>
            <SymbolInstance>
              <ResourceId>Library://ZZ_Test/Symbols/ag_PRE_S_05_LBT.SymbolDefinition</ResourceId>
              <ParameterOverrides />
              <Unit>Meters</Unit>
              <SizeContext>MappingUnits</SizeContext>
              <SizeX>20</SizeX>
              <SizeY>20</SizeY>
            </SymbolInstance>
          </CompositeSymbolization>
        </CompositeRule>
      </CompositeTypeStyle>
    </VectorScaleRange>
  </VectorLayerDefinition>
</LayerDefinition>
But When i save this resource with Maestro 5.0.0.75.32 :
« System.Exception: Le serveur distant a retourné une erreur : (559) MgDbXmlException.: Le module d'erreur personnalisé ne reconnaît pas cette erreur. ---> System.Net.WebException: Le serveur distant a retourné une erreur : (559) MgDbXmlException.
   à System.Net.HttpWebRequest.GetResponse()
   à OSGeo.MapGuide.MaestroAPI.HttpServerConnection.SetResourceXmlData(String resourceid, Stream content, Stream header) dans c:\Program Files (x86)\Jenkins\jobs\Maestro trunk\workspace\OSGeo.MapGuide.MaestroAPI.Http\HttpServerConnection.cs:ligne 651
   --- Fin de la trace de la pile d'exception interne ---
   à Maestro.Editors.Common.XmlContentErrorDialog.CheckAndHandle(Exception ex, String origXml, Boolean bDisplay) dans c:\Program Files (x86)\Jenkins\jobs\Maestro trunk\workspace\Maestro.Editors\Common\XmlContentErrorDialog.cs:ligne 60
   à Maestro.Editors.ResourceEditorServiceBase.UpdateResourceContent(String xml) dans c:\Program Files (x86)\Jenkins\jobs\Maestro trunk\workspace\Maestro.Editors\ResourceEditorServiceBase.cs:ligne 326
   à Maestro.Base.Editor.EditorContentBase.OnBeforeSave(Object sender, CancelEventArgs e) dans c:\Program Files (x86)\Jenkins\jobs\Maestro trunk\workspace\Maestro.Base\Editor\EditorContentBase.cs:ligne 163
   à Maestro.Editors.ResourceEditorServiceBase.OnBeforeSave() dans c:\Program Files (x86)\Jenkins\jobs\Maestro trunk\workspace\Maestro.Editors\ResourceEditorServiceBase.cs:ligne 339
   à Maestro.Editors.ResourceEditorServiceBase.Save() dans c:\Program Files (x86)\Jenkins\jobs\Maestro trunk\workspace\Maestro.Editors\ResourceEditorServiceBase.cs:ligne 245
   à Maestro.Base.Commands.SaveResourceCommand.Run() dans c:\Program Files (x86)\Jenkins\jobs\Maestro trunk\workspace\Maestro.Base\Commands\SaveResourceCommand.cs:ligne 45
   à ICSharpCode.Core.WinForms.ToolBarCommand.OnClick(EventArgs e)
   à System.Windows.Forms.ToolStripItem.HandleClick(EventArgs e)
   à System.Windows.Forms.ToolStripItem.HandleMouseUp(MouseEventArgs e)
   à System.Windows.Forms.ToolStripItem.FireEventInteractive(EventArgs e, ToolStripItemEventType met)
   à System.Windows.Forms.ToolStripItem.FireEvent(EventArgs e, ToolStripItemEventType met)
   à System.Windows.Forms.ToolStrip.OnMouseUp(MouseEventArgs mea)
   à System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
   à System.Windows.Forms.Control.WndProc(Message& m)
   à System.Windows.Forms.ScrollableControl.WndProc(Message& m)
   à System.Windows.Forms.ToolStrip.WndProc(Message& m)
   à System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
   à System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
   à System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
It's true that in maestro symbol instance panel for composite style, I never seen the choice "MappingUnits" "DeviceUnits" for composite style...
Thanks for your help
Rémy
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20130918/19f3ab45/attachment.html>
