[mapguide-users] MapGuide Measrue Tool - Start and Stop function
RenoSun renolionheart at gmail.com
Wed Sep 25 11:21:28 PDT 2013
Thank you so much Jackie
However, the defaults setting for both buttons are disabled, and it didn't
turn to enabled when I start to measure the distance/area.
<http://osgeo-org.1560.x6.nabble.com/file/n5079987/Capture1.png>
<http://osgeo-org.1560.x6.nabble.com/file/n5079987/Capture2.png>
I already updated the C:\Program Files\Autodesk\Autodesk Infrastructure Web
Server Extension 2014\www\fusion\widgets\Measure.js to the latest version.
* Fusion.Widget.Measure
 * $Id: Measure.js 2686 2013-04-05 11:44:39Z jng $
Would you please tell me which files that I also should modify to make it
works???
Thank you very much.
View this message in context: http://osgeo-org.1560.x6.nabble.com/MapGuide-Measrue-Tool-Start-and-Stop-function-tp5059440p5079987.html
