[mapguide-users] Resize the taskpane in fusion
Ryan Northcott rnorthcott at gmail.com
Fri Sep 27 06:49:44 PDT 2013
I wasn't going to repeat the same just grab and grip the frame separator
reply, but now that you indicate this is the reason you are trying to
override that built in function... here are my two cents, I didn't actually
look around in the template folders
You might need to attack the underlying frame html tag code in the
templates that fusion uses to load up and throw it one a page (ie where you
see the id='TaskPane' type of  <frame  html tag )
then mess with the frame borders / spacing of those, or the parent Frame
Set margin widths, they have left/right and top/bot pairings to manage
those separately.
<frameset cols="2" rows="1" border="1" framespacing="5" frameborder="1">
   <frame name="mapFrame" marginwidth="2" noresize="false" />
   <frame name="TaskFrame" marginwidth="5" noresize="false" />
</frameset>
something like that to think about and play with in your  LimeGold Template
On Fri, Sep 27, 2013 at 3:56 AM, JamesDudden
<jamesdudden at blueyonder.co.uk>wrote:
> Yes I'm trying to make the taskpane wider for the exact reason you state
> because a lot of users complain it's too tricky to grab the side and expand
> it.
> I'm not sure if enlarging the cursor would help but it's worth a shot. It
> seems to be the zone where the cursor changes to the re-size option is too
> small so maybe if there was a way to increase that ...?
> Software-Matters
> http://osgeo-org.1560.x6.nabble.com/Resize-the-taskpane-in-fusion-tp5080267p5080440.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20130927/6d3684a2/attachment.html>
