[mapguide-users] How to get mapname by HTTP API
Roberto Quintela Modia
roberto.quintela at gmail.com
Tue Apr 1 00:39:26 PDT 2014
I have tryed unsuscribe me 40 times and nothing
Any idea?
Thanks
Kintela
@esekintela
El 01/04/2014, a las 02:37, Jackie Ng <jumpinjackie at gmail.com> escribió:
> You have to make a MgMap server-side from a Map Definition and keep a
> reference to its name so you can manipulate and interact with that same map
> for future HTTP requests.
> There is no actual HTTP API to actually do this (you had to have some code
> in Java/PHP/.net to do this), but for 2.6 there is such an API, it's called
> CREATERUNTIMEMAP (see: http://trac.osgeo.org/mapguide/wiki/MapGuideRfc134)
> There is an intermediate solution for older versions: Install the
> mapguide-rest extension (https://github.com/jumpinjackie/mapguide-rest) and
> you'll have something similar to CREATERUNTIMEMAP, but keep in mind that
> this is a PHP-based solution.
> - Jackie
> View this message in context: http://osgeo-org.1560.x6.nabble.com/How-to-get-mapname-by-HTTP-API-tp5132348p5132372.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
