[mapguide-users] Multiple Schema Mappings found for class
Hans Milling
hm at geograf.dk
Thu Apr 3 02:28:22 PDT 2014
Hi all
Using MapGuide 2.2 I try to add a layer based on a WFS feature source, but I
get the following error when I add the layer and select the feature source:
The remote server returned an error: (559) MgFdoException.:
An exception occurred in FDO component.
'pdk:theme_pdk_kommuneplantillaeg_aflyst_v'.
Can anyone explain what this error is all about? The WFS works fine in
MapInfo. If I search the XML the layer
"theme_pdk_kommuneplantillaeg_aflyst_v" is only listed once.
The URL for the WFS is:
http://geoservice.plansystem.dk/wfs?service=WFS&request=GetCapabilities&version=1.0.0
The details of the exception (if anyone cares) is:
System.Exception: The remote server returned an error: (559)
MgFdoException.:
---> System.Net.WebException: The remote server returned an error: (559)
MgFdoException.
at System.Net.HttpWebRequest.GetResponse()
at OSGeo.MapGuide.MaestroAPI.HttpServerConnection.OpenRead(String req) in
c:\working\JenkinsCI\home\slave_win\jobs\Maestro
5.0.x\workspace\OSGeo.MapGuide.MaestroAPI.Http\HttpServerConnection.cs:line
1435
--- End of inner exception stack trace ---
1451
at OSGeo.MapGuide.MaestroAPI.HttpServerConnection.GetClassNames(String
resourceId, String schemaName) in
1975
at
Maestro.Editors.LayerDefinition.LayerPropertiesSectionCtrl.Bind(IEditorService
service) in c:\working\JenkinsCI\home\slave_win\jobs\Maestro
5.0.x\workspace\Maestro.Editors\LayerDefinition\LayerPropertiesSectionCtrl.cs:line
46
at
Maestro.Editors.LayerDefinition.VectorLayerEditorCtrl.Bind(IEditorService
5.0.x\workspace\Maestro.Editors\LayerDefinition\VectorLayerEditorCtrl.cs:line
54
at Maestro.Base.Editor.LayerDefinitionEditor.Bind(IEditorService service)
5.0.x\workspace\Maestro.Base\Editor\LayerDefinitionEditor.cs:line 68
at Maestro.Base.Editor.EditorContentBase.set_EditorService(IEditorService
value) in c:\working\JenkinsCI\home\slave_win\jobs\Maestro
5.0.x\workspace\Maestro.Base\Editor\EditorContentBase.cs:line 111
at Maestro.Base.Services.OpenResourceManager.Open(IResource res,
IServerConnection conn, Boolean useXmlEditor, ISiteExplorer siteExp) in
5.0.x\workspace\Maestro.Base\Services\OpenResourceManager.cs:line 191
at Maestro.Base.Services.OpenResourceManager.Open(String resourceId,
5.0.x\workspace\Maestro.Base\Services\OpenResourceManager.cs:line 259
Best regards
Hans Milling...
View this message in context: http://osgeo-org.1560.x6.nabble.com/Multiple-Schema-Mappings-found-for-class-tp5132808.html
