[mapguide-users] Mapgiude OS Mobile Viewer
Srecko Lipovsek
srecko.lipovsek at kaliopa.si
Thu Apr 24 07:32:09 PDT 2014
Go to Default.debug.js to line 520 and change 'PNG' to 'JPG' ...
After that run 00_minifyJS.bat for minification (get file Default.min.js).
If you will use JPG, transparency will not work ...
http://stackoverflow.com/questions/9147883/only-png-supports-transparency-is-that-true
<http://stackoverflow.com/questions/9147883/only-png-supports-transparency-is-that-true>
View this message in context: http://osgeo-org.1560.x6.nabble.com/Mapgiude-OS-Mobile-Viewer-tp4941633p5136915.html
