[mapguide-users] SHP join MySQL xs:schema
pcardinal
pierre.cardinal at sympatico.ca
Sun Feb 9 06:44:47 PST 2014
The XML of the Feature Source is
It is a SHP Feature Source with a Join on a MySQL table.
When I try to create a Theme with a Column from the MySQL table, I have the
following error from Maestro "Unable to read data from the selected column:
Bad document. Expected element xs:schema."
How can I correct the problem?
MGOS2.5, Maestro5.1, IIS
<http://osgeo-org.1560.x6.nabble.com/file/n5102779/Capture.png>
View this message in context: http://osgeo-org.1560.x6.nabble.com/SHP-join-MySQL-xs-schema-tp5102779.html
