[mapguide-users] How to change the initial task pane URL programatically
Liglio liglio at pobox.com
Tue Feb 11 05:45:06 PST 2014
James,
Thanks for your reply. My problem is that the Initial Task Pane URL must be
dynamic, because it must write the host name where the application is
installed, due a cross-domain issue (I am using iframes). I don't want to
manually edit the weblayout for every server I install de application (or in
the case of using Amazon EC2, stop/start modify the host IP). I want to edit
the Initial Task Pane URL from the server-side. Get the host IP (ok its
easy) and write somewhere http://hostIP/TaskPaneInit.aspx. If you know how
to do it, I appriciate.
View this message in context: http://osgeo-org.1560.x6.nabble.com/How-to-change-the-initial-task-pane-URL-programatically-tp5102583p5103155.html
