[mapguide-users] How to change the initial task pane URL programatically
Flipper scotth at mpowerinnovations.com
Wed Feb 12 07:20:47 PST 2014
Yes exactly! I want to move the taskpane to the left area, outside of the
fusion frame...I don't have the issue of 2 different domains, but same
general problem
On Feb 12, 2014 9:15 AM, "Liglio [via OSGeo.org]" <
ml-node+s1560n5103406h73 at n6.nabble.com> wrote:
> Flipper,
> Your layout is similar to mine. See the images.[image: Initial map view][image:
> TaskPane opened]
>  If you reply to this email, your message will be added to the discussion
> below:
> http://osgeo-org.1560.x6.nabble.com/How-to-change-the-initial-task-pane-URL-programatically-tp5102583p5103406.html
>  To unsubscribe from How to change the initial task pane URL
> programatically, click here<http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=5102583&code=c2NvdHRoQG1wb3dlcmlubm92YXRpb25zLmNvbXw1MTAyNTgzfDMyMzM0MDY4Mg==>
> NAML<http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
View this message in context: http://osgeo-org.1560.x6.nabble.com/How-to-change-the-initial-task-pane-URL-programatically-tp5102583p5103409.html
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20140212/203d12f7/attachment.html>
