[mapguide-users] Maestro Horizontal align setting in layer label style
Steve G stevenlgolden at gmail.com
Fri Feb 28 14:19:09 PST 2014
I believe it depends on the type of layer (polygons/point/line).
http://images.autodesk.com/adsk/files/studiousersguide.pdf
This is studio users guide, but the concept should be the same.  See the
note on page 98.
NOTE Horizontal and vertical alignment settings are not available for area
layers. Only the vertical alignment setting is available for line layers.
Horizontal
and vertical alignment settings are available for point layers that display
fixed
labels instead of symbols.
So...Left, Right, Center should work for point features, not lines or
polygons.
Steve G
View this message in context: http://osgeo-org.1560.x6.nabble.com/Maestro-Horizontal-align-setting-in-layer-label-style-tp5106629p5106718.html
