[mapguide-users] Mapguide 4j set up
Smith Roman
autisi at yahoo.com
Sat Jan 4 10:39:05 PST 2014
Hi All,
I am trying to set up mapguide 4j using the guidelines in this link
https://github.com/jumpinjackie/mapguide4j
I am getting the following error when i try to run the application.
Getting org.scala-sbt sbt 0.11.3 ...
:: problems summary ::
:::: WARNINGS
module not found: org.scala-sbt#sbt;0.11.3
==== local: tried
C:\play\play-2.2.1\repository\local\org.scala-sbt\sbt\0.11.3\ivys\ivy.
xml
==== Maven2 Local: tried
file://C:\Users\ROMAN/.m2/repository/org/scala-sbt/sbt/0.11.3/sbt-0.11
.3.pom
==== typesafe-ivy-releases: tried
http://repo.typesafe.com/typesafe/ivy-releases/org.scala-sbt/sbt/0.11.
3/ivys/ivy.xml
==== Maven Central: tried
http://repo1.maven.org/maven2/org/scala-sbt/sbt/0.11.3/sbt-0.11.3.pom
:: UNRESOLVED DEPENDENCIES ::
:: org.scala-sbt#sbt;0.11.3: not found
:: USE VERBOSE OR DEBUG MESSAGE LEVEL FOR MORE DETAILS
unresolved dependency: org.scala-sbt#sbt;0.11.3: not found
Error during sbt execution: Error retrieving required libraries
(see C:\play\play-2.2.1\framework\.\sbt\boot\update.log for complete log)
Error: Could not retrieve sbt 0.11.3
I am using play 2.2.1 with mapguide 2.5.2.
Any ideas ?
Regards,
Smith.
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20140104/7c3c4728/attachment.html>
