[mapguide-users] Select from TaskPane with Fusion
renardchan
emailvalide at yahoo.fr
Wed Jan 8 03:11:27 PST 2014
Hi (i use mapguide os 2.4),
I would like select an object of my map from the task pane.
What i want to do :
1) I have the name of an object. I found it in my database with php in the
task pane.
2) Now i would like select this object on the viewer.
So i have two questions,
1)I understand that i can execute a query with xml. How can i create this
XML code(with php or javascript) ? and do you have some example?
2)With the XML code, how can i select the object from the task pane to the
viewer?
Thanks by advance.
Regards
ps: I have found how to get my sessionid and mapname.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Select-from-TaskPane-with-Fusion-tp5096938.html
