[mapguide-users] HELP: An exception occurred in DB XML component.
Zac Spitzer zac.spitzer at gmail.com
Fri Jan 10 08:44:24 PST 2014
if possible, try to avoid using access databases
On Fri, Jan 10, 2014 at 4:13 PM, JamesDudden
<jamesdudden at blueyonder.co.uk>wrote:
> Gabriele,
> Thank you for your reply , I really appreciate your time. Luckily this time
> we went back to an older server back up and this has worked without to much
> loss of data.
> Moving forward I will be using this as reference and making sure the dbxml
> files are backed up regularly.
> Thanks again.
> RegardsJD
> Software-Matters
> http://osgeo-org.1560.x6.nabble.com/HELP-An-exception-occurred-in-DB-XML-component-tp5097289p5097364.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer
+61 405 847 168
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20140110/b2338b3d/attachment.html>
