[mapguide-users] Changing default mouse pointer
Andreotti maurizio.maselli at andreotti.ch
Fri Jan 24 03:38:49 PST 2014
Dear all,
I am using mapguide with maestro 5.1 i have a question about changing the default mouse pointer when opening a map. When you open a map with ajax viewer the default toolbar initialized is the selection tool, there is a possibility the setup a configuration file to initialize the ajax viewer with the zoom tool. I saw in numerous forum the option to change the shape of the pointer but not the default toolbar. Probably there will be a modification of ajamappane.templ in the viewer folder of mapguide but i am not sure.
Thank you for reply
Best regards
Maurizio
