[mapguide-users] set filter on layer at runtime make selection tools not work
Franco Caloni
franco.caloni at stacec.com
Tue Jul 1 09:03:43 PDT 2014
Hi all,
following the samples in Maestro SDK (ModifyParcelsFilter.cs), I'm setting a
filter on a layer at runtime.
The filter works and the features become filtered, but then when I try to
select the features on the filtered layer I got this error:
http://prntscr.com/3ycbja
"Internal server error" in GetSelectionProperties.php
This is what I do:
before the app starts I create "Session:" objects (layer, map &
FlexibleLayout)
------------------- startup -----------------------
string cnfg = ConfigurationManager.AppSettings["mgwebinipath"].ToString();
MapGuideApi.MgInitializeWebTier(cnfg);
MgUserInformation userInfo = new MgUserInformation("theuser",
"thepassword");
MgSite site = new MgSite();
site.Open(userInfo);
var sessionId = site.CreateSession();
string agent = "http://localhost/mapguide/mapagent/mapagent.fcgi";
IServerConnection conn = ConnectionProviderRegistry.CreateConnection(
"Maestro.Http",
"Url", agent,
"SessionId", sessionId.ToString());
var layoutMio = "Library://Demo/Layouts/L1.ApplicationDefinition";
var layerVerticale = "Library://Demo/Layers/Verticale.LayerDefinition";
var mappaMia = "Library://Demo/Mappe/MappaDemo.MapDefinition";
var featureClass = "Default:vimpianti";
var wrkmappa = mappaMia;
if (conn.ResourceService.ResourceExists(wrkmappa))
// create a Session: Layer
ILayerDefinition layerFiltrato =
(ILayerDefinition)conn.ResourceService.GetResource(layerVerticale);
IVectorLayerDefinition vl =
(IVectorLayerDefinition)layerFiltrato.SubLayer;
vl.FeatureName = featureClass;
string ldfId = "Session:" + sessionId +
"//VerticaleRuntime.LayerDefinition";
conn.ResourceService.SaveResourceAs(layerFiltrato, ldfId);
// create a Session: Map
MapDefinition rtmap =
(MapDefinition)conn.ResourceService.GetResource(mappaMia);
IMapLayer layerold = rtmap.GetLayerByName("Verticale");
rtmap.AddLayer(layerold, "", "VerticaleFiltrato", ldfId);
rtmap.MapLayer.RemoveAt(2);
string MapId = "Session:" + sessionId +
"//MappaRunTime.MapDefinition";
rtmap.Name = "MappaF";
conn.ResourceService.SaveResourceAs(rtmap, MapId);
// create the Session Flexible Layout
ApplicationDefinitionType layoutRes =
(ApplicationDefinitionType)conn.ResourceService.GetResource(layoutMio);
layoutRes.MapSet[0].Map[0].Extension.Any[0].InnerText = MapId;
layoutRes.MapSet[0].Map[0].Extension.Any[0].InnerXml = MapId;
string resId = "Session:" + sessionId +
"//SessionLayout.ApplicationDefinition";
conn.ResourceService.SaveResourceAs(layoutRes, resId);
// go to the application page
Response.Redirect("/cartografia.aspx?ApplicationDefinition=" + resId
+ "&SESSION=" + sessionId);
------------------- end of startup -----------------------
To set the filter at runtime (in the Task pane):
var session = Request.Params["SESSION"];
var mapName = Request.Params["MAPNAME"];
"Maestro.Http",
"Url", agent,
"SessionId", session);
IMappingService mpSvc =
(IMappingService)conn.GetService((int)ServiceType.Mapping);
string rtMapId = "Session:" + conn.SessionID + "//" + mapName + ".Map";
RuntimeMap rtMap = mpSvc.OpenMap(rtMapId);
int layerIndex = rtMap.Layers.IndexOf("VerticaleFiltrato");
RuntimeMapLayer layer = rtMap.Layers[layerIndex];
ILayerDefinition ldf =
(ILayerDefinition)conn.ResourceService.GetResource(layer.LayerDefinitionID);
IVectorLayerDefinition vl = (IVectorLayerDefinition)ldf.SubLayer;
if (string.IsNullOrEmpty(vl.Filter))
vl.Filter = "rid = 10265";
else
vl.Filter = "";
string ldfId = "Session:" + conn.SessionID +
"//VerticaleFiltered.LayerDefinition";
conn.ResourceService.SaveResourceAs(ldf, ldfId);
ldf.ResourceID = ldfId;
RuntimeMapLayer replace = mpSvc.CreateMapLayer(rtMap, ldf);
replace.ExpandInLegend = layer.ExpandInLegend;
replace.Group = layer.Group;
replace.LegendLabel = layer.LegendLabel;
replace.Name = layer.Name;
replace.Selectable = layer.Selectable;
replace.ShowInLegend = layer.ShowInLegend;
replace.Visible = layer.Visible;
rtMap.Layers.RemoveAt(layerIndex);
rtMap.Layers.Insert(layerIndex, replace);
replace.ForceRefresh();
rtMap.Save();
Selecting features on other layers give no error, so I suppose the problem
is in the runtime filtered layer, but don't know what I'm doing wrong here
Thanks for your help,
Franco
