[mapguide-users] Selection Tolerance in QUERYMAPFEATURES
Jackie Ng jumpinjackie at gmail.com
Wed Jul 9 17:56:53 PDT 2014
I'm finding that selection matches the size of the symbol.
I can see the need to window select these features at lower levels, but I
don't know if this is an actual issue.
Point selections are always inflated by a small "pixel buffer" so the query
geometry is always a polygon, but this buffer is always a constant *screen
space* value meaning clicks on points have better chance of registering at
higher scales than ones at lower scales.
- Jackie
View this message in context: http://osgeo-org.1560.x6.nabble.com/Selection-Tolerance-in-QUERYMAPFEATURES-tp5150001p5150382.html
