[mapguide-users] Selection Tolerance in QUERYMAPFEATURES
Jackie Ng jumpinjackie at gmail.com
Thu Jul 10 09:05:38 PDT 2014
All (?) mapagent operations have JSON equivalents if you pass in
FORMAT=application/json
Mind you this is XML-to-JSON kind of JSON (where nearly every XML element
turns out as a JSON array), but JSON nonetheless.
- Jackie
View this message in context: http://osgeo-org.1560.x6.nabble.com/Selection-Tolerance-in-QUERYMAPFEATURES-tp5150001p5150514.html
