[mapguide-users] Odg: Re: Mapguide 2.5 and FDO 3.4
Srecko Lipovsek
srecko.lipovsek at kaliopa.si
Wed Jun 4 14:27:26 PDT 2014
Hi FDO 3.9 is not compatible with MG 2.5.
This patched version is for upcoming release of MG 2.6 ...
LP, S.L.
-------- Izvirno sporočilo --------
Od: "resident_root [via OSGeo.org]" <ml-node+s1560n5144096h38 at n6.nabble.com>
Datum:
Za: Srečko Lipovšek <Srecko.Lipovsek at kaliopa.si>
Zadeva: Re: Mapguide 2.5 and FDO 3.4
Hi, i am trying to patch my Mapguide 2.5.2 64bits instalation but i can't. I tried this:
I put SQLServerSpatialProvider.dll from this link (that appears works for you): http://download.osgeo.org/mapguide/patches/fdo3.9_ticket864/SQLServerSpatialProvider_x64_ticket864.zip in Fdo folder (i maked backup of the original dll), then rigth on new dll, clic Properties->Unblock (cause Windows blocks dll from unknows sources), i restarted Mapguide Service, dont work, i put 3.9 instead of 3.8 on providers.xml, i restarted Mapguide service, dont work, i changed the ownership of the dll to SYSTEM like the other libraries in Fdo folder, i restarted Mapguide Service, dont work, is Mapguide 2.5.2 working with this 3.9 Fdo library?.
I tried with this one too:
http://download.osgeo.org/mapguide/patches/fdo3.9_ticket864/SQLServerSpatialProvider_x64_ticket_864_and_889.zip i got same result. Mapguide throws a error open FeatureSource from SQLServer and GetCapabilities throws Unknow error. Thank you for your help.
If you reply to this email, your message will be added to the discussion below:
http://osgeo-org.1560.x6.nabble.com/Mapguide-2-5-and-FDO-3-4-tp5138527p5144096.html
To unsubscribe from Mapguide 2.5 and FDO 3.4, click here<http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=5138527&code=c3JlY2tvLmxpcG92c2VrQGthbGlvcGEuc2l8NTEzODUyN3w4NDkwMzc2MTc=>.
NAML<http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
View this message in context: http://osgeo-org.1560.x6.nabble.com/Odg-Re-Mapguide-2-5-and-FDO-3-4-tp5144103.html
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20140604/727afb6d/attachment.html>
