[mapguide-users] OpenLayers3 Mapguide layer Tiled
Jackie Ng
jumpinjackie at gmail.com
Wed Jun 11 06:25:23 PDT 2014
There is no formal tiled Map Definition support in ol3.
However as a workaround, you could use the latest 0.8 release of
mapguide-rest (Get it here:
https://github.com/jumpinjackie/mapguide-rest/releases/tag/v0.8-pre) to
serve your map as an XYZ tileset and consume it through ol3 via
ol.source.XYZ
Be aware that this XYZ tileset support in mapguide-rest is experimental.
- Jackie
View this message in context: http://osgeo-org.1560.x6.nabble.com/OpenLayers3-Mapguide-layer-Tiled-tp5145206p5145289.html
