[mapguide-users] QUERYMAPFEATURES and requestdata = 3 throws NpE
Scott Hameister
scotth at mpowerinnovations.com
Tue Jun 17 10:58:23 PDT 2014
Really Sorry...I misread the Problem...I thought you were trying to select
a point feature and Zoom out by a percentage (which doesn't work)...also
in a Lat/Long Psuedomercator even adding units instead of percent is hard
becuase a single unit can be a large Area.
S+I thought that is what you were accidently doing..Sorry for the
confusion
Scott Hameister | www.mpowerinnovations.com
________________________________________
mPower Innovations
Director of Product Development
1051 N Lynndale Drive, Suite 2A, Appleton, WI 54914
T: 920-830-4053 ext. 204 | F: 920-955-4057
TF: 877-269-6971 ext. 204 | C: 920-419-6250
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of mjirku
Sent: Monday, June 16, 2014 11:01 PM
To: mapguide-users at lists.osgeo.org
Subject: Re: [mapguide-users] QUERYMAPFEATURES and requestdata = 3 throws
NpE
Hi Flipper,
I am little bit confused, what do you mean by real world unit?
Original data in database (MS SQL) are in JTSK.
Working mapdefinition (mapdefinition which returns bounds) uses:
PROJCS["CzechJTSK/5.Krovak",GEOGCS["CzechJTSK/5.LL",DATUM["CzechJTSK/5",SP
HEROID["BESSEL",6377397.155,299.15281535]],PRIMEM["Ferro",
-17.6666666666667],UNIT["Degree",0.017453292519943295]],PROJECTION["Krovak
"],PARAMETER["longitude_of_center",42.50000000000000],PARAMETER["latitude_
of_center",49.50000000000000],PARAMETER["azimuth",30.28813975989891],PARAM
ETER["pseudo_standard_parallel_1",78.50000000000000],PARAMETER["false_east
ing",0.000],PARAMETER["false_northing",0.000],PARAMETER["scale_factor",0.9
99900000000],UNIT["Meter",1.00000000000000]]
While I need for my custom client side application WGS84 pseud., I am
using in mapdefinition coordinate system defined as:
PROJCS["WGS84.PseudoMercator",GEOGCS["LL84",DATUM["WGS84",SPHEROID["WGS84"
,6378137.000,298.25722293]],PRIMEM["Greenwich",0],UNIT["Degree",0.01745329
2519943295]],PROJECTION["Popular
Visualisation Pseudo
Mercator"],PARAMETER["false_easting",0.000],PARAMETER["false_northing",0.0
00],PARAMETER["central_meridian",0.00000000000000],UNIT["Meter",1.00000000
000000]]
Should I change something to make it work?
View this message in context:
http://osgeo-org.1560.x6.nabble.com/QUERYMAPFEATURES-and-requestdata-3-thr
ows-NpE-tp5145379p5146205.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
