[mapguide-users] Fusion 2.6 (AIMS 2015) ZoomToSelection Problem
    amorsell
    andy.morsell at autodesk.com
    Tue Jun 17 14:34:02 PDT 2014
I tried that and it did not have any effect.  Here's a way to easily see this
problem in Fusion 2.6:
With the Sheboygan dataset, create a new layer from the Trees SDF data
connection.  Copy the Sheboygan map to a new map, assign WGS84
PseudoMercator, add the Trees layer to it, and also make the Roads layer
selectable.  Create a new Fusion layout based on the Slate template and add
the map to it.  Open the layout in a browser.  Select a tree point and press
Zoom Selection.  Based on what I'm seeing, nothing should happen.  Select a
road line and press Zoom Selection.  A zoom to 1:1 in the wrong area should
happen.
Doing this same thing with the same Sheboygan dataset in Fusion 2.4 will
result in the point centering but not zooming (which is expected behavior)
and the line will center and zoom correctly.
Thank you.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Fusion-2-6-AIMS-2015-ZoomToSelection-Problem-tp5145845p5146390.html
