[mapguide-users] Fusion 2.6 (AIMS 2015) ZoomToSelection Problem
amorsell andy.morsell at autodesk.com
Fri Jun 20 19:09:06 PDT 2014
Would it be possible to get just the needed dll(s) so I can test the fix?
Thank you,
Andy
From: Jackie Ng [via OSGeo.org] [mailto:ml-node+s1560n5147102h79 at n6.nabble.com]
Sent: Friday, June 20, 2014 5:39 PM
To: Andy Morsell
Subject: Re: Fusion 2.6 (AIMS 2015) ZoomToSelection Problem
You will have to check out 2.6 or trunk and build everything up to the MapGuideCommon library (that contains the fix)
- Jackie
If you reply to this email, your message will be added to the discussion below:
http://osgeo-org.1560.x6.nabble.com/Fusion-2-6-AIMS-2015-ZoomToSelection-Problem-tp5145845p5147102.html
To unsubscribe from Fusion 2.6 (AIMS 2015) ZoomToSelection Problem, click here<http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=5145845&code=YW5keS5tb3JzZWxsQGF1dG9kZXNrLmNvbXw1MTQ1ODQ1fDUyODY4ODExOQ==>.
NAML<http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
View this message in context: http://osgeo-org.1560.x6.nabble.com/Fusion-2-6-AIMS-2015-ZoomToSelection-Problem-tp5145845p5147108.html
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20140620/b07d0b28/attachment.html>
