[mapguide-users] TCPDF ERROR: Can't open image file
Iulia Tamas iulia_tamas30 at yahoo.com
Tue Jun 24 02:43:39 PDT 2014
Hello,
I'm using Mapguide Open Source 2.5.2 and when trying to generate pdf file via the QuickPlot function I have the following message in server error log:
PHP Warning:  fopen(http://e-logistic-integration-plans.gdfsuez.com/mapguide/fusion/widgets/QuickPlot/GeneratePicture.php?session_id=071d36a0-fb74-11e3-8000-005056a56a99_fr_MTI3LjAuMC4x0AFC0AFB0AFA&map_name=Map53a92d85427f9&print_size=285,171.9&print_dpi=150&box=-70.467930795167,0,8.373363908283,0,8.373363908283,63.647920203306,-70.467930795167,63.647920203306&normalized_box=-70.467930795167,0,8.373363908283,0,8.373363908283,63.647920203306,-70.467930795167,63.647920203306&scale_denominator=387&rotation=0&widthLegend=0) [<a href='function.fopen'>function.fopen</a>]: failed to open stream: Unable to find the socket transport "ssl" - did you forget to enable it when you configured PHP? in D:\\IsiomIFY\\OSGeo\\MapGuide\\Web\\www\\fusion\\lib\\tcpdf\\tcpdf.php on line 8082
The .pdf file is not generated and the following error is displayed in browser:
TCPDF ERROR: Can't open image file: http://e-logistic-integration-plans.gdfsuez.com/mapguide/fusion/widgets/QuickPlot/GenerateMapLegend.php?session_id=0c1f2ef6-fae8-11e3-8000-005056a56a99_fr_MTI3LjAuMC4x0AFC0AFB0AFA&map_name=Map53a8429eb3f04&print_size=408,258.90000000000003&print_dpi=150&widthLegend=68
Any ideas?
Thank you,
Iulia Tamas
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20140624/6c4263f7/attachment.html>
