[mapguide-users] Layer not showing Coordinate system override from feature source
Ernesto Vega ernesvega at gmail.com
Fri Jun 27 07:30:18 PDT 2014
I have a shape file feature source and I have added it a Coordinate system
override as seen below:
LOCAL_CS["Non-Earth (Kilometer)",LOCAL_DATUM["
Local Datum",0],UNIT["Kilometer", 1000],AXIS["X",EAST],AXIS["Y",NORTH]]
If I preview it in Maestro, I can easily drill down to it the deepest
scale, and coordinate system appears to be as defined above.  I can see
that conversion from Non-Earth (Meter) to Non-Earth(Kilometer) is done
correctly and map displays as expected.
The problem is when I create a layer out of it. The conversion just doesn't
happen and If I preview such layer I can't get to the same scale. Am I
missing something here ? Is this supposed to happen ?
Any pointers will be more than welcome.
I'm using Mapguide OpenSource 2.6 and Maestro 6.0a1
Regards,
Ernesto
"If opportunity doesn't knock, build a door."
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20140627/f600553e/attachment.html>
