[mapguide-users] Layer not showing Coordinate system override from feature source
evegaba ernesvega at gmail.com
Fri Jun 27 13:23:19 PDT 2014
Thanks Steve. Here is my layer definition:
<?xml version="1.0"?>
<LayerDefinition xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:xsd="http://www.w3.org/2001/XMLSchema" version="2.4.0"
xsi:noNamespaceSchemaLocation="LayerDefinition-2.4.0.xsd">
  <VectorLayerDefinition>
<ResourceId>Library://Chile/Data/calles_ciudades_y_provincia.FeatureSource</ResourceId>
    <Watermarks />
    <FeatureName>Default:calles_ciudades_y_provincia</FeatureName>
    <FeatureNameType>FeatureClass</FeatureNameType>
    <PropertyMapping>
      <Name>FeatId</Name>
      <Value>FeatId</Value>
    </PropertyMapping>
    <PropertyMapping>
      <Name>NAME</Name>
      <Value>NAME</Value>
    </PropertyMapping>
    <Geometry>Geometry</Geometry>
    <VectorScaleRange>
      <LineTypeStyle>
        <LineRule>
          <LegendLabel />
          <LineSymbolization2D>
            <LineStyle>Solid</LineStyle>
            <Thickness>1</Thickness>
            <Color>ff000000</Color>
            <Unit>Points</Unit>
            <SizeContext>MappingUnits</SizeContext>
          </LineSymbolization2D>
        </LineRule>
      </LineTypeStyle>
    </VectorScaleRange>
  </VectorLayerDefinition>
</LayerDefinition>
I see no reference to the Coordinate System. Perhaps it is inherited from
the feature source. Which is below:
<FeatureSource xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:noNamespaceSchemaLocation="FeatureSource-1.0.0.xsd">
  <Provider>OSGeo.SHP</Provider>
  <Parameter>
    <Name>DefaultFileLocation</Name>
    <Value>%MG_DATA_FILE_PATH%calles_ciudades_y_provincia.shp</Value>
  </Parameter>
  <SupplementalSpatialContextInfo>
    <Name>Non-Earth (Meter)</Name>
    <CoordinateSystem>LOCAL_CS["Non-Earth (Kilometer)",LOCAL_DATUM["Local
Datum",0],UNIT["Kilometer",
1000],AXIS["X",EAST],AXIS["Y",NORTH]]</CoordinateSystem>
  </SupplementalSpatialContextInfo>
</FeatureSource>
I appreciate your help on this.
Ernesto
View this message in context: http://osgeo-org.1560.x6.nabble.com/Layer-not-showing-Coordinate-system-override-from-feature-source-tp5148417p5148479.html
