[mapguide-users] QueryMapFeatures handle lines as areas in MapGuide 2.5
Hans Milling
hm at geograf.dk
Tue Mar 4 02:35:16 PST 2014
I am using the OGR provider (MapInfo TAB files). Perhaps this also changed
for the OGR provider then. But is there a way to specify how you want your
QueryMapFeatures to behave?
Alternate I have to loop trough the results and do my own "line intersects
rectangle" on the geometry, but that I would like MapGuide/ORG provide to
already have done for me. If the default behavior is changed, then there
should be an option to select to behave differently.
Regards
Hans Milling...
View this message in context: http://osgeo-org.1560.x6.nabble.com/QueryMapFeatures-handle-lines-as-areas-in-MapGuide-2-5-tp5107071p5107364.html
