[mapguide-users] Mapguide 2.5 and FDO 3.4
Srecko Lipovsek
srecko.lipovsek at kaliopa.si
Sat May 10 09:21:14 PDT 2014
Ok,
Here is test data: TestData_864.zip (530 MB)
<https://www.wetransfer.com/downloads/ef8cc9e56b57d3fde785df513ef8f87020140510160355/418dac96a6c0b97446e87ac1ec4fb9b020140510160355/5e98f0>
- MS SQL 2008 R2 Database
- MGP
Layer buildings with OR filter: type = 'Bank' OR type = 'Shop' OR type =
'business'
- testing map render (seems OK, need to check profiler results CPU, Reads,
- testing selection (selection does'n work on right feature but selection
renders some other feature)
- testing tooltip (tooltip doesnt work right, but shows data from some other
feature, look at tooltip text, alyays the same)
Also need to test filter in theme rule.
This is wrong query from profiler when requesting tooltip data on this layer
with filter:
SELECT "A"."geometry","A"."primaryindex","A"."name","A"."osm_id","A"."type"
FROM "dbo"."buildings" AS "A" WHERE A."type"=N'Bank' OR A."type"=N'Shop' OR
A."type"=N'business' AND A.[geometry].STIntersects(@P1)=1
View this message in context: http://osgeo-org.1560.x6.nabble.com/Mapguide-2-5-and-FDO-3-4-tp5138527p5139576.html
