[mapguide-users] Mapguide 2.5 and FDO 3.4
Srecko Lipovsek
srecko.lipovsek at kaliopa.si
Mon May 12 11:22:20 PDT 2014
Ok,
Seems like OK. Parentheses are now OK too.
Just another thing, probably not have anything with this, but it is probably
consequence of comparing strings while rendering layer theme items.
While testing filter in theme rule condition I notice that lower / upper
cases in condition filter are probably not handled.
Example:
Layer Filter text (*type = 'bank' OR type = 'sHOp' or type = 'busineSS' or
type = 'ParKinG' or type = 'supermarkeT'*) return data from SQL regardless
lower/upper cases.
Theme rule condition example filter in UPPER case (*type = 'BANK' OR type =
'SHOP'*) don't render them, because text in DB is in lower case.
It is litle bit confusing, SQL return data regardless upper/lower case,
while theme condition dont render them if thre is not perfect match.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Mapguide-2-5-and-FDO-3-4-tp5138527p5139828.html
