[mapguide-users] Mapguide 2.5 and FDO 3.4
Srecko Lipovsek
srecko.lipovsek at kaliopa.si
Thu May 15 07:25:08 PDT 2014
No, strings are not modified, they are the same as specified in filter ...
SQL return data regardless lower/upper case, but theme rule condition don't
Here is example, SQL return data, but no condition is used ...
<?xml version="1.0"?>
<LayerDefinition xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:xsd="http://www.w3.org/2001/XMLSchema" version="2.4.0"
xsi:noNamespaceSchemaLocation="LayerDefinition-2.4.0.xsd">
<VectorLayerDefinition>
<ResourceId>Library://00_test_864/DataConnection.FeatureSource</ResourceId>
<Watermarks />
<FeatureName>Default:buildings</FeatureName>
<FeatureNameType>FeatureClass</FeatureNameType>
<Filter>type = 'bank' OR type = 'sHOp' or type = 'busineSS' or type =
'ParKinG' or type = 'supermarkeT'</Filter>
<PropertyMapping>
<Name>name</Name>
<Value>name</Value>
</PropertyMapping>
<PropertyMapping>
<Name>osm_id</Name>
<Value>osm_id</Value>
</PropertyMapping>
<PropertyMapping>
<Name>type</Name>
<Value>type</Value>
</PropertyMapping>
<Geometry>Geometry</Geometry>
<ToolTip>Concat(name, '\ntype: ' , type)</ToolTip>
<VectorScaleRange>
<AreaTypeStyle>
<AreaRule>
<LegendLabel>filter</LegendLabel>
<Filter>type = 'BanK' OR type = 'ShoP' or type =
'BusinesS'</Filter>
<AreaSymbolization2D>
<Fill>
<FillPattern>Solid</FillPattern>
<ForegroundColor>FFFF0000</ForegroundColor>
<BackgroundColor>FFFF0000</BackgroundColor>
</Fill>
<Stroke>
<LineStyle>Solid</LineStyle>
<Thickness>1</Thickness>
<Color>ff000000</Color>
<Unit>Points</Unit>
<SizeContext>MappingUnits</SizeContext>
</Stroke>
</AreaSymbolization2D>
</AreaRule>
<AreaRule>
<LegendLabel>filter1</LegendLabel>
<Filter>type = 'ParkinG' or type = 'SupermarkeT'</Filter>
<Fill>
<ForegroundColor>FF008000</ForegroundColor>
<BackgroundColor>FF008000</BackgroundColor>
</Fill>
<Stroke>
<Unit>Points</Unit>
</Stroke>
</AreaRule>
<AreaRule>
<LegendLabel>default</LegendLabel>
<Filter />
<Fill>
<ForegroundColor>ffffffff</ForegroundColor>
<BackgroundColor>ffffffff</BackgroundColor>
</Fill>
<Stroke>
<Unit>Points</Unit>
</Stroke>
</AreaRule>
</AreaTypeStyle>
</VectorScaleRange>
</VectorLayerDefinition>
</LayerDefinition>
View this message in context: http://osgeo-org.1560.x6.nabble.com/Mapguide-2-5-and-FDO-3-4-tp5138527p5140493.html
