[mapguide-users] Consuming MG tiled maps as XYZ tiled maps (for OpenLayers/Leaflet/etc)
Jackie Ng jumpinjackie at gmail.com
Thu May 22 03:05:38 PDT 2014
In case anyone's interested. There is an actual way to serve Map Definitions
as XYZ tiles. It's a bit of a hack as it requires the use of the RenderMap
API (as GetTile/RenderTile is not flexible enough for serving XYZ tiles).
I have an experimental implementation in mapguide-rest and blogged about it
here:
http://themapguyde.blogspot.com.au/2014/05/solving-xyz-problem-in-mapguide.html
- Jackie
View this message in context: http://osgeo-org.1560.x6.nabble.com/Consuming-MG-tiled-maps-as-XYZ-tiled-maps-for-OpenLayers-Leaflet-etc-tp5134024p5141841.html
