[mapguide-users] How to update FDO provider
Mal mfernandes at rand.com
Tue Nov 4 21:02:59 PST 2014
the table shows that for MG2.6 I need the 3.9 ver FDO.
Where do I find that version, all I could find is the 3.8
http://fdo.osgeo.org/content/downloads
Two reasons that I am updating the FDO.
1. as per the note on the maestro/UserGuides/UpdatingFDOInstallation
"When you install MapGuide, it only has a subset of the avalible FDO
providers. This will hopefully be fixed in the future, but for now you can
manually upgrade you FDO provider collection. These are the steps required
to update your FDO providers: "
and
2. I tried creating a Data connection to a MS access database, But got
errors, and is the main reason I was updating my FDO provider
   a. new resource
   b. feature source
   c. ODBC provider
   d. add  button, selected my mdb file
   e. test connection and got the following error
FDO Connection Status:
	The remote server returned an error: (559) MgFdoException.:
An exception occurred in FDO component.
Error occurred in Feature Source
(Session:fc1f832e-64a6-11e4-8000-000c29d0a8e5_en_MTI3LjAuMC4x0AFC0AFB0AFA//fa96f6ad-9a71-4fb9-b0b2-c30d8923a27d.FeatureSource):
RDBMS: [Microsoft][ODBC Driver Manager] Data source name not found and no
default driver specified
- MgFdoConnectionManager.Open() line 333 file
c:\working\build_area\mapguide\2.6.0\x64\mgdev\server\src\common\manager\FdoConnectionManager.cpp
- MgFdoConnectionManager.CacheFdoConnection() line 1097 file
- MgFdoConnectionManager.Open() line 1089 file
 (Cause: , Root Cause: )
- MgFeatureServiceHandler.ProcessOperation() line 83 file
c:\working\build_area\mapguide\2.6.0\x64\mgdev\server\src\services\feature\FeatureServiceHandler.cpp
- MgOpTestFeatureSourceConnection.Execute() line 100 file
c:\working\build_area\mapguide\2.6.0\x64\mgdev\server\src\services\feature\OpTestFeatureSourceConnection.cpp
- MgServerFeatureService.TestConnection() line 243 file
c:\working\build_area\mapguide\2.6.0\x64\mgdev\server\src\services\feature\ServerFeatureService.cpp
- MgFdoConnectionManager.Open() line 366 file
In regards to updating the FDO provider, I have been following pretty much
the same steps as Mark provided for his Win server2008 and it does not work
on my win7/64
View this message in context: http://osgeo-org.1560.x6.nabble.com/How-to-update-FDO-provider-tp5171261p5171269.html
