[mapguide-users] tooltips in 2.6 (migration from 2.2. to 2.6)
Andrew DeMerchant andrew.demerchant at gemtec.ca
Wed Nov 19 05:51:46 PST 2014
I figured out the problem with the AJAX viewer -  Seems as though
despite upgrading the schema for older weblayouts, the "maptip" tool
still doesn't appear to be an option to add to the toolbar. I tried
manually editing the xml to add that in there, but that didn't do the
trick (the button shows, but the tooltips still don't work right). The
only solution I've found is to recreate a new weblayout, which will make
the old tooltips work fine, as is (no change what so ever from 2.2).
Seems this is a bug - I'll add it to trac.
On 14/11/14 9:22 AM, Andrew DeMerchant wrote:
> That trick definitely solves my Fusion problems...as soon as I did
> that, they worked fine - even using the older nested concat from 2.2.
> I'm still not seeing these tooltips in the AJAX viewer though....which
> is what I'd really like to get going. Fusion's nice and all, but it's
> still a bit clumsy / clunky when dealing with tooltips, and for at
> least one project of mine, tooltips are key. Any ideas on how to get
> the AJAX tooltips going?
> On 14/11/13 8:32 PM, GordonL wrote:
>> Make sure you have the MapTip button in the toolbar.  I think it is a bug, no
>> tooltips in Fusion without it.
>> View this message in context:http://osgeo-org.1560.x6.nabble.com/tooltips-in-2-6-migration-from-2-2-to-2-6-tp5170043p5172923.html
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> GEMTEC Email Signature
> GEMTEC Limited <http://www.gemtec.ca/>
> *Andrew DeMerchant*
> tel: 506.453.1025  /  toll-free: 1.877.243.6832
> fax: 506.453.9470
*Andrew DeMerchant*
fax: 506.453.9470
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20141119/fc350425/attachment.html>
Name: not available
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20141119/fc350425/attachment.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20141119/fc350425/attachment-0001.png>
