[mapguide-users] Loading tif using GDAL
Farhan Khan
mrfarhankhan at gmail.com
Thu Oct 2 06:51:06 PDT 2014
ok, I resolved this. The problem was that the tif file was located that was
not in the path of server installation. I created a folder in the server
installation path i.e. C:/Program Files/OSGeo/MapGuide/Server/TestData/ and
placed the tif file there. Then, I created a GDAL Feature Source, using the
following
1. Type - Single
2. File System
DONE !
On Tue, Sep 30, 2014 at 9:41 AM, Farhan Khan <mrfarhankhan at gmail.com> wrote:
> ok, i tried it. the same exception pops up again
> "unknown entity reference".
> how can i resolve this ?
> On Mon, Sep 29, 2014 at 11:30 PM, Farhan Khan <mrfarhankhan at gmail.com>
> wrote:
>> I am really grateful for your help.
>> In the GDAL Feature Source window, I'm using the following
>> 1. Type - Single
>> 2. File System
>> I am using the Local Preview button at the bottom. As per your
>> suggestion, I will now try to use the Preview button on the toolbar and
>> report back on how it went.
>> Thanks
>> Farhan!
>> On Mon, Sep 29, 2014 at 11:22 PM, Steve G <stevenlgolden at gmail.com>
>> wrote:
>>> In the GDAL Feature Source window, what method are you using to connect
>>> to
>>> the data?
>>> 1. Type - Single or Composite
>>> 2. File System or Alias
>>> Also, are you using the Local Preview button at the bottom or the Preview
>>> button on the toolbar? You should use the Preview button on the toolbar.
>>> It will load the schema view in a new browser window. You should be
>>> able to
>>> see a link "View Data" and once you click on that, the right frame will
>>> be
>>> populated with all the tif files being exposed. If it says "total
>>> entries:-1" then something failed. Also remember to
>>> In the not so recent past, I have had issues with the Composite type
>>> method:
>>> http://osgeo-org.1560.x6.nabble.com/Step-by-Step-for-ECW-and-MGOS-2-4-tp4995445p4998405.html
>>> If this is the method that you have been using and it fails, try using
>>> the
>>> Single type method (choose the folder where all the tif files are). And
>>> I
>>> would also start from the beginning (open a new resource and select
>>> single
>>> method). For some reason I've noticed that if you try to change from
>>> composite to single type method, you can't...it seems like you can't
>>> purge
>>> the configuration even after a save.
>>> Steve
>>> View this message in context:
>>> http://osgeo-org.1560.x6.nabble.com/Loading-tif-using-GDAL-tp5164516p5164792.html
>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20141002/d4625070/attachment.html>
