[mapguide-users] Map scales inaccurate by %13.528
Hans Milling hm at geograf.dk
Thu Oct 9 03:00:54 PDT 2014
This is not simply because your monitor is not 96 DPI? I think that MapGuide
defaults to 96 DPI as screen resolution. A 1920x1080 monitor can be 16" or
32" and there is no way for the browser to tell MapGuide this. Howerver if
you generate a PDF or image the scale should be correct (Except if you print
the PDF and do not select "actual size" in the print dialog.
Best regards
  Hans Milling...
View this message in context: http://osgeo-org.1560.x6.nabble.com/Map-scales-inaccurate-by-13-528-tp5166479p5166644.html
